Softail rear shock disassembly jig
If you have a floor jack, you can make this simple jig to compress the shock for disassembly. See the photos. I used yellow pine 2x3's, a circular saw and decking screws. I made dado cuts (grooves) to provide strength. It worked really slick and was cheap to make. The shock disassembled is from my 2003 FLSTFI with 60k miles. I was experiencing a squeek as I rode. I thought it might be metal-on-metal rubbing inside the shocks. There was a lot of dirt and debris inside but I think the squeek actually came from the mounting bolt at the rear of the shock. I greased them up before assembly. No more squeek.
https://www.dropbox.com/sh/oxzrcuir9...YDs6WgIya?dl=0
The following 3 users liked this post by mplazz:
