2007 FXSTC Turn signal issue
I have a 2007 FXSTC. Last year I replaced the Battery (it was a aftermarket one) and right away I noticed the left turn signal on the dash seemed to flicker with the vibrations (only when it wasn't turned on). today I noticed its doing it more and now the right side is starting to do it, and it also illuminates the actual blinkers just as a flickering, and seems more frequent with higher RPM's.. I pulled the seat looking for a rubbing wire or loose connection even tightened the battery terminals, then pulled the dash and they all look good. anyone have a idea were to look next? The bike has only 9,000 miles. Does anyone have a copy of the wiring diagram?
Thanks ahead for any help
KENDQ
KENDQ
SAME EXACT PROBLEM I have with my 2004 sportster 1200!
[QUOTE=kendq;17335034]I have a 2007 FXSTC. Last year I replaced the Battery (it was a aftermarket one) and right away I noticed the left turn signal on the dash seemed to flicker with the vibrations (only when it wasn't turned on). today I noticed its doing it more and now the right side is starting to do it, and it also illuminates the actual blinkers just as a flickering, and seems more frequent with higher RPM's.. I pulled the seat looking for a rubbing wire or loose connection even tightened the battery terminals, then pulled the dash and they all look good. anyone have a idea were to look next? The bike has only 9,000 miles. Does anyone have a copy of the wiring diagram?
I put on ape hangers last year not a problem, then at the end of the season the right indicator light started flickering with the rpms of the engine. Now it stays fully lit or starts flickering! I’m pretty sure it has to do with the wires I ran it through the handlebars but I’m not hundred percent sure so I was wondering if anybody knows about this problem and could help us!
bout3fitty
06-11-2014 11:46 PM
Stiggy
02-21-2012 05:42 PM
