Rear wheel part number is 40900486, it's around the $800 mark. Should fit the 13-17 Breakout without a problem, same bearing/sleeve size, although different swingarms dimensions in width they are the same.
Thank you for the part number Blackp5ca. I really appreciate it.
Where do you find these part numbers? Can I find them myself? I need part numbers for some factory blacked-out pieces from CVO Pro Street Breakout (like triple tree, rear brake/signal housings, etc..)
