Super Tuner Pro
Am hoping to get bike with Super Tuner Pro. Can't seem to find software anywhere. Any ideas? Or do I have to connect tuner to laptop to access software? I'm beginning to wonder if this system is obsolete!
https://cimg2.ibsrv.net/gimg/www.hdf...f7963b1628.jpg |
Originally Posted by 883
(Post 20233129)
I'm not experienced with the Screamin' Eagle tuners, but I think that the Super Tuner Pro is in fact obsolete... I believe the only tuner that Harley currently supports is the Screamin' Eagle Pro Street Tuner... which is totally EPA and CARB certified.... it will only adjust the ECM within EPA & CARB limits.. IIRC..... The Super Tuner Pro was at the heart of the "disagreement" between the MoCo and the EPA, that led to the EPA Consent decree.... If you haven't heard of that fiasco, just google "Harley EPA consent decree" and you will have a couple weeks worth of reading... If I am confusing the names of the various HD tuners, I'm sure someone will correct me... |
The tuner will be on a Fatboy with stage 1. I downloaded the Street Tuner software - I presume that wont work with the Super Tuner? The Super Tuner can only be set at a dealer otherwise I believe.
Download from here
https://streetperformancetuner.harle...reetTuner.aspx That box gets married to a VIN. |
(Post 20233882)
Not even a dealer can use the old version (non EPA compliant files) of the Super Tuner... It is all part of the MoCo's responsibilities under the EPA consent decree... they had to buy back all unsold non-EPA compliant HD tuners, and are not allowed to sell a tuner, support a tuner, or use an HD tuner that is outside EPA parameters.... I'm sure there are some dealers that may tune outside EPA parameters on the sly, but they can't use an HD product... probably a PowerVision, TTS or other non-HD tuner... FWIW... If the Fatboy has already been flashed with a proper tune from the old software/firmware of the Super Tuner, there really is no need, barring new mods, to retune the bike... |
(Post 20233977)
(Post 20234039)
Except that it has bad popping - owning a tuner should be about tweaking. When I had a V&H tuner on my 2019 Fat Bob, I regularly fiddled with throttle sensitivity etc - all part of the fun. Mr Harley obviously does not want to make it easy to adjust the older bikes!!
I absolutely agree.... If you can can get it to update, even to the newer EPA approved format, it will allow tweaking, just not as much tweaking due to EPA restrictions. |
© 2024 MH Sub I, LLC dba Internet Brands
