Auxiliary light for 07 FatBoy Question(s)
G'day all,
Just about to order auxiliary lighting for my 07 fatboy. I think someone answered this for me a while back but I can find the post / thread. Does anybody know the difference between the "Deluxe auxiliary lighting kit" and the "auxiliary light kit for fatboy models" ? Do they both fit? I want to put a detachable windshield later on also.
The other question is... with whichever I choose, what else do I have to buy? Do you need to buy turn signals seperately? Bulbs, wiring, etc?
Thanks guys,
DeanO
Thanks guys,
DeanO
RE: Auxiliary light for 07 FatBoy Question(s)
I'm in the middle of my install and I have the deluxe kit, whichincludes the turn signal relocation and a new cover (behind the headlamp). The only item I had to purchase is the bulbs for the passing lamps (plus some other trim rings which will look better). Keep in mind that the nacelle doesn't fit with the deluxe kit.
Cam
Cam
Deluxe Kit will not work with a NACELLE kit
Regular AUX kit for 07 fatboy will not work with the backplate(stock) unless u wanna dent it(LOL) but will fit fine with a NACELLE kit
AUX kit for Fatboy the new one will fit with the stock backplate and fit with nacelle
I have the regular AUX kit, didnt have the NACELLE kit at time of instal and dented my stock backplate, I fixed that tho with tossing it and putting on the NACELLE
Hey Steve,
Was a bit confused by all of that but basically if I don't want a nacelle, then the deluxe lighting kit is the way to go and will bolt straight up to what I have and will have everything I need except the bulbs right?
DeanO
DeanO
ORIGINAL: vertigo14
Fit with nacelle
Fit with detachable windshield (if I choose to get one)
vertigo14, what backplate are you referring to?
Hah... ok if you never ever want a Nacelle.. then the deluxe light kit will work with the stock back plate you have on your bike now. (the back plate i am naming is the chrome deal that sits right behind the headlamp now.. you know what I mean now?
If you have an 07 fatboy (not sure on the 08s: ---Fits '00-later FLSTF and '06 FLST models.---) there is a new AUX light kit on the HD Internet catalog thing... that will fit with both the stock back plate and the nacelle
The NEW AUX kit for fatboy:
69287-07
I mean why not plan for an upgrade.. the deluxe one isn't that much different...
Yeah you will need the lamps as well... and T/S relocation kit if you go that route as well.
You can also get a kit that converts the PASSING lamps you are putting on to easy to replace bulb part only.. heh kit is 50 bucks a piece or such. But you will need the lamps themselves first
69287-07
ORIGINAL: dmac1968
Hey Steve,
DeanO
Hey Steve,
DeanO
ORIGINAL: vertigo14
Yeah here: this is the AUX Lighting kit that will work with the stock chrome plate thats right behind the headlamp now(stock)
69287-07
When you decide to put on the nacelle kit.. after you put on the aux kit.. you can use the windshield I do from HD..
Low Profile, slightly smoked
58651-97A
or the:
Standard Hight one but its clear and be cut down:
58649-97A
Again both of the above windshields are quick detachable and for NACELLE KIT WITH AUX LIGHTING
69287-07
58651-97A
or the:
58649-97A
ORIGINAL: WARG
Anyone have a part number for this kit? I am looking at getting one and I want a kit that will do the following:
Fit with nacelle
Fit with nacelle
