Fork Fluid
Old May 25, 2022 | 11:49 AM
Rogue Brit's Avatar
Rogue Brit
3rd Gear
Default Fork Fluid
Hi,
I have a 2017 Breakout and looking to do a fork service. Looking for best fork fluid brand and weight to use.
Thanks
Old May 25, 2022 | 11:53 AM
brakeless's Avatar
brakeless
What's your Owners Manual say? Have a Service Manual? Brand wise they all to meet the same spec.
Old May 25, 2022 | 01:59 PM
Rogue Brit's Avatar
Rogue Brit
3rd Gear
have owners and service manual. Both suggest harley. Heard there are better brands out there.
Old May 25, 2022 | 02:24 PM
brakeless's Avatar
brakeless
There are certainly less expensive one's. I use Bel Ray personally.
Old May 25, 2022 | 03:46 PM
Rogue Brit's Avatar
Rogue Brit
3rd Gear
I came across that name a lot.
Thank you
Old May 25, 2022 | 04:09 PM
MarlinSpike's Avatar
MarlinSpike
Veteran: Coast Guard
Bel-Ray. Been around longer than dirt. Good stuff, all their oils are top-notch.
Old May 25, 2022 | 05:09 PM
chopper_man's Avatar
chopper_man
I love the Screamin Eagle fork oil. Rides very well and got rid of the excess nose dive.
Old May 26, 2022 | 09:00 AM
hattitude's Avatar
hattitude
If you are satisfied with your front end performance, stick with the same weight fork oil. If you want to change performance, you can change weights, or even mix weights, to get a performance you like. Just remember, the thicker the oil, the less compliant (stiff) and thinner the oil the more compliant (bouncy) your front end will perform.
Another thing to note, fork oils get thinner, when they heat up. Most have a basic spec and then a 100°C spec. Harley Type E is 20W, but drops to 7.95W @ 100°C. If you are a hard rider, who frequently "works" his suspension hard, you may want to start with a heavier weight fork oil..
I believe most HD bikes come OEM with their Type E fork oil (20W).
If you want a more compliant (bouncy) front end you could go with HD Type B fork oil (10W)...
If you are a canyon carver and want a stiffer front end (Ha, I said stiffer front end) you could go with the Screamin' Eagle Type heavy fork oil. It is also 20W, but fades (gets thinner) less at high temp than Type E.
HD also used to make a very heavy SE fork end oil called extra heavy, which is like 60W... I would guess for racing only, probably unsuitable for street use...
I use Bel-Ray High Performance Fork oil... They make it in 5W, 7W, 10W, 15W, 20W, and 30W. So you can pick a weight and give it try, or there are numerous weights for mixing...
The beauty of fork oil is that it's not that hard to change, and if you pick a weight that doesn't suit you, it's not too hard to change it to something more/less compliant....
Good luck with your decision...
PS- Here's a chart by Spectro Oil on fork oils. It shows the "thinning" of the oil at temp..
Old May 26, 2022 | 09:37 AM
MarlinSpike
Even 20wt is considered fairly heavy oil when discussing fork oils. I tend to use 10w to 15w or a mixture of the two to make a 12.5wt. Your riding style, your loaded body weight [ single or double riders], and types of terrain riding on are the gauges to deciding on the wt oil you want. Trial and error are where most people find what works the best for them.
Also, the oil level is easily used to change a forks/suspension characteristics. Rebound and Damping = weight of oil and level of oil in the forks.
One other note - Different brands of oils have different actual "weights" [ viscosities ] even if they have the same weight printed on the bottle.
Old May 26, 2022 | 12:12 PM
Rogue Brit's Avatar
Rogue Brit
3rd Gear
Awesome, thanks for all the knowledge
