Fr. Master cylinder. Rebuild
had duels on my roadking bled them fine, single on my softy, cap was loosely on, did the slight pull got some bubbles, let set overnight to see if air would make its way up, nothing when slight pull again,, going to do another bleed, with cap loose when you open bleed valve gravity should let fluid through system? maybe a stubborn air pocket, I make sure not to let fluid get low,
Tie the lever back like it is applied and leave it over night.
Wire ties, tape , rope , strap or what ever.
https://www.revzilla.com/motorcycle/...iABEgLBjvD_BwE Speed bleeders
WP
Bled again no air, pulled the m/c from handle bar, attached to an old set put in fluid, squeezed handle not a drip came out, pulled piston seals, they're in right, now I did notice that when pulled original at the end of spring is like a flat washer but not on the one in rebuild kit, matter, I wouldn't think so, going to cycle warehouse near me has millions of parts
