tyre wear = wobble?
Old 05-12-2008, 09:15 AM
WAhog's Avatar
WAhog
WAhog is offline
Default tyre wear = wobble?
My fatboy has a rapid wobble around 70mph+. We recently found that the stearing head was loose and it has since been tightened but I'd really appreciate some feedback on the following:
- could the loose stearing head have cause uneven tyre wear?
- could the uneven tyre wear cause the wobble?
It's definitely NOTHING to do with wind/cross wind!
Gonna fit a metzler front to replace theoriginal Dunlop
Thanks
Old 05-12-2008, 10:07 AM
tk353's Avatar
tk353
tk353 is offline
Default RE: tyre wear = wobble?
yes and yes. Also I had the same and it was a bad wheel bearing. If you do change the front tire out go with the Metzler. I did and it is much better handling and smoother and quieter. I use the Dunlop on the rear as it last longer than the Metzler. The Metzler on the front seems to last as long as the Dunlop did.
Old 05-12-2008, 06:38 PM
breaknbad's Avatar
breaknbad
breaknbad is offline
My wobble was from a slightly bent rim.
It caused abnormal wear too. All spokes were tight too. Cant figure that one out.
Bought a used one from a friend who replaced his rims with aftermarket ones. No problems since.
David
Old 05-13-2008, 06:48 AM
WAhog's Avatar
WAhog
WAhog is offline
Thanks both for the feedback, andfor the tips about the bearing and rims, will check it out.
Ride safe!
kneesinthebreeze24
Wheels/Tires
07-28-2019 09:37 AM
Jbcswifty
05-03-2016 06:31 PM
Rmuller
02-06-2011 05:09 PM
oroepke1
01-02-2008 11:42 AM
Mr Wonderful
07-05-2007 07:40 PM
Quick Reply: tyre wear = wobble?
