Help Oil Pouring Out From The Air Cleaner
First, has the bike been sitting for a long time? All Harley's use a dry sump oil system that "keeps" the oil in an external tank. But over time, in some cases when the check valve is stuck or worn, it can "leak" down into the crank case in as little time as overnight.
If it has too much oil in the crank case, starting the engine can make it blow out through the breather tubes in the filter assembly, and it will continue to until the excess is scavenged out by the pump.
Not sure what you did with or too the filter cover. But the stock round cover is normally held on with one screw in the center. If its been replaced with an aftermarket assembly like an S&S, they use three screws.
I believe that the EVO motor on your bike the filter under the cover is held on with three screws.
iwillfixthem4u
12-07-2013 03:42 PM
