calling all 2007 Fatboy owners..
Well after rattling a few cages no one seems to want to address this issue. Its not the fault of my bike, other HD motorcycles, or even the dealers.
This issue is a core issue that someone at Milwaukee decided it was worth it had greater benefit than detriment to engineer this bike in such a manner and release it.
As much as I love the color of my bike (Olive Pearl) and the few numbers of Fatboys produced with this color its going to be real hard to let her go, but I honestly will not be happy riding it, nor feel 100% solid on it.
Most especially since I know that it was FIXED for the 2008-2009 model years.
Considering I got my Fatty and Sporty within the first month of me riding PERIOD, Id definitely say I was in Honeymoon fever. Part of this issue is my fault for not separating the passion from the purchase.
But make no mistake about it, Harley, for as long as they have been building bikes, should have had the sense to only release the bike when they had a PROPER resolution of the issue that caused them to add friggen camber to the front axle.
Have the dealer check the bushings. I had the same problem, took it in and they did a little push and pull and got it right. Apparently HD bushings are bushleig
WILL THIS THREAD EVER DIE?
Ok guys I have an early model 07 (with the offset front end). I have fixed the offset. It is NOT the bearings, or the axel that causes the offset. It is the front wheel and the lower legs. If you measure the offset of the front wheel on an early 07 vs. the offset on an 08 you will see a significant difference! I put an 08 front wheel and 08 lower legs and fixed the problem. I also had uneven tire wear, and since the repair (12000 miles ago) that problem has been resolved.
