What are the Pros-Cons on Exhaust wrap??
Many of you guys that may have worked with exhaust wrap, wondering if there where any issues,
Just been iching to wrap the top headers, not sure after installation if I would like em. And would it cause fading to the black ceramic coating after a few months?. Did the search on the forum and theres great info there far as helping with the installing.
I would be doing it for functionality, since my pipes are not shielded.
I saw some great work done on the forum, any info would be great.
Thanks,
Winter sucks
Thanks,
Winter sucks
The wrap will definitely help you with the lack of heatshields, but will increase the internal temp of your pipes significantly. Hopefully it will not hurt the ceramic coating. Definitely buy the coating/spray that you apply to outside of the wrap. It will help with discoloration and fraying.
If you search the web you'll find differing opinions on the subject...most of the negatives come from car/race guys where the wrap keeps so much heat inside pipes the pipes deteriorate/become brittle and fall apart...hence way race cars moved to ceramic coating.
Another problem can be rust, another reason to apply the coating to the wrap...if you don't the wrap will absorb moisture easily
Hope this helps...there used to be a website called why exhaust wrap sucks, but I can't find it
Like I said, most of the negatives came from people who used it on their cars
Used it on my sporty for lack of heat sheild it looks great. Keeps my wife from burning her leg and seemed to give it a little more spunk. On my Nighttrain it's just cosmetic. I high temp powder coated the pipes and wrapped them. The pc fell off it was so damn hot. went back and painted them w/ high temp rattle can paint and its worked great ever since. Black ceramic will fade eventually anyway. As stated above make sure you paint the wrap after its on the pipes looks much better for longer.
so you painted your wraps with high temp paint or just the pipes before you wrapped?
