I am putting the FXCW seat on my C model. I have the fxcw seat and support bracket I also ordered the frame caps. I am being told that I also need to order a pan that goes under the seat?? Is this correct?
Yep..I've done the same swap...you do need the pan. You'll also want to get some color-coated plugs for the 4 holes that will be left on the frame after you remove the Rocker C seat.
No seat pan needed, it will look like this after the swap.
hey speedsnice, will the seat stay in place without the seat pan? did you lower your bike at all, because it's seem like your seat lower than regular rocker stock seat?
Your bike looks great. Could you tell me where you bought your license plate mount and how you filled in the fender holes? I'm also looking for the plugs to go in the frame holes after replacing my seat. Thanks again for your help.
