Fatboy/heritage rear fender help!!
Old 03-13-2009, 07:34 AM
Yanksta's Avatar
Yanksta
Yanksta is offline
Default Fatboy/heritage rear fender help!!
I have a rear fender off of a heritage softail i am unaware of the year. i am going to try to fit it on a 2004 fatboy. When did the fenders change this fender is not newer then a 2004 i am for sure. What is everyone's thoughts on this. I hate to get it painted and then put it on and it not fit so i would like to know before hand. to me all the fatboy and heritage rear fenders later then i think 2007 look the same clear back into the 90's. I am getting this painted next week so help me fast thanks everyone.
Old 03-13-2009, 08:01 AM
David The Hutt's Avatar
David The Hutt
David The Hutt is offline
I am no expert, but I will bet $100 it wont fit. I coule be totally wrong, but usually there is some small detail that wont go smoothly. If you are sheet metallicly inclined (if thats a word), I am sure you can hot-fix it.
If all else fails, call the dealer or bike body shop and find out what small changes (if any) were made over the years
Old 03-13-2009, 08:11 AM
ChopperBill's Avatar
ChopperBill
ChopperBill is offline
Received 3,983 Likes on 1,208 Posts
The Heritage fender has those indents for the turn signal. I don't like e'm. Sure did limit my search for new tins.
Old 03-13-2009, 08:27 AM
Yanksta's Avatar
Yanksta
Yanksta is offline
Default reply
yes i have noticed the indents. actually the tins that are on my bike now have heritage fenders so the turn signals have been moved down to the indents so i am still good there. the only other difference i have seen is the license plate whole. i have looked on ebay and mine is definently newer then 95. my rear fender tail light hole is a rectangle hole and has a little tab to screw the light into. everything 95 and older has some raised up rails for it to mount to. any more input would be great so far i am thinking this should fit.
Old 03-13-2009, 08:29 AM
anubisss's Avatar
anubisss
anubisss is offline
The other difference is the holes for the solos eat. The heritage has 2 holes for the solo seat in the top of the fender. I would bet it will fit as long as your bike is pre 2007.
Old 03-13-2009, 08:34 AM
Yanksta's Avatar
Yanksta
Yanksta is offline
Default fender
this fender only has one hole on the top. it is going to be rainy this weekend i may swap them out just to be sure before they get sprayed.
Old 03-13-2009, 08:38 AM
Yanksta's Avatar
Yanksta
Yanksta is offline
Default anubissss
off topic but how do you get a pic of you bike that big to post on all your comments.
Old 03-13-2009, 08:43 AM
anubisss's Avatar
anubisss
anubisss is offline
Put it on photobucket and use the direct link when you hit the picture icon above.
Old 03-13-2009, 08:44 AM
BK Meyers's Avatar
BK Meyers
BK Meyers is offline
Default fender
The rear fenders on the Heritage changed for the 2000 model year (same year as the frame and engine change).
A major cosmetic difference in the fender from the 99-earlier units is that the 200+ units have more material below the strut and an almost flat line in that same area, as opposed to the curve of the 99-earlier units.
Unfortunately there were also some changes after 2000. Harley lists multiple part numbers for the Heritage rear fenders from 2000-later.
Later,
BK
Old 03-13-2009, 08:52 AM
David The Hutt
if all else fails, MAKE it fit. Nothing a hammer, a blowtorch, a grinder and a sharp eye for detail wont fix
Quick Reply: Fatboy/heritage rear fender help!!
