I8SMK4U |
03-28-2009 09:46 PM |
Sounds like the same stuff I just went through. I ended up replacing the coil, Ignition module, and plug wires. Make sure the wires are 100% hooked up right to the coil. Make sure there is 12 Volts going to the coil also. A good trouble shooting trick I learned is, I made a jumper wire that went from the + terminal directly to the coil. Put a disconnect in the middle of it cause the bike won't shut off unless you disconnect it. I bought my bike used and had to redo a lot of "custom" work from the previous owner.
