LED Mini-Bullet Run/Turn/Brake&Badlands III Problem!Need Help!
Tracy, when i installed mine i was like "UH OH!!!!" A lot of wires on one end and not a lot on the other. Its really not that hard if you have a service manuel. With that being said i would have to think that like said prior its something as simple as a bad ground or crossed wires. It is plug and play, they are right about that but there is a catch. With mine i had to cut my stock wire harness from my stock lights and break. I then plugged the badlands into the bike then the stock harness back to the badlands. No here is where the "plug and play" went out the window. You now have to connect the cut end of the stock harness to your new signals and break light. If i remember right i didnt end up using one of the wires. the only issue i had was my tail light not working as a running light but everything else worked great. My heartland minni billets are wired for stop, run, turn and are bright as heck so not having the brake as a running light was not a big deal to me. I hope this some how gives you a little insight for when you have to go back to the stealer?? anything else, just hit me up bro.!
Good luck! I just really don't understand how you could let that bike leave there building with out the lights working ?????????? Thats the problem these days, nobody does there job. Why is it when you find a shop/mechanic/dealer or whatever that has good customer service like DR.V or you pay somebody to do some work and they actually do it right its called "going the extra mile"????? I mean isn't that the way its just supposed to be? This is by no means a down play of the level of service from DR.V-TWIN cause they are above and beyond. Its just a shame. Sorry to vent!!!! Anyway just thought i'd help out with my experience so you have some leverage with the stealer.
UPDATE!! I went down to the stealer, and they fixed the RUN/BRAKE/TURN problem, by removing my Badlands III Load Equalizer, and replacing it with a "Harley" RUN/BRAKE/TURN Load Equalizer. They didn't even bother to call and get my approval for this!!! Sounds shadey, but what do I know? I'm not knowledgeable about mechanics or electrics . so it's hard to argue any point. They also said that the RSD side-mount plate RUN/STOP light coming on when I brake, and then going out for a second, and coming back on is a problem within the light itself???
Well... Sounds like I didn't have the proper equipement needed the first time out. Should the RSD side-mount tail light RUN/BRAKE problem be an easy fix? Or am I going to need to take the damn thing off completely and send it back to them?
Not an issue with the run/brake/turn module Dr. . That is my fault, not yours. My concern is with the RSD side mount plate light being on in run mode, and then coming on for brake mode, but when I release brake, it goes out for a second, and then comes back on into RUN mode. Can just the "light" portion be removed and fixed? Or do I need to have the side-mount plate and light unit completely removed?
