XBONES owners who went with FWD Controls~HELP !
Took off the floorboards , and stock controls off my 2010. According to HD , 08 and up fwd controls will work . I purchased controls from an 08 Xbones and I'm having problems .. Ist : kickstand (ez enuff I can change that out )....2nd : the RT side with master cyl will not bolt up properly and is hitting the exhaust (samson).. Has anyone done this or experienced anything like this ? ....Did they change anything in 2010 ? . |
i'm about the farthest thing from an expert , so you might want to wait until someone who actually knows what they're talking about shows up
my guess is the samson exhaust is designed to work with a stock xbones with floorboards , they didn't plan for anyone running forwards . if you replace your stock exhaust you'll probably find they fit . now since you don't want to do that you could try contacting samson to see if they have any advice |
Originally Posted by not_so_newb
(Post 6365103)
my guess is the samson exhaust is designed to work with a stock xbones with floorboards , they didn't plan for anyone running forwards . if you replace your stock exhaust you'll probably find they fit . now since you don't want to do that you could try contacting samson to see if they have any advice http://i252.photobucket.com/albums/h...5/DSC05999.jpg |
ok ... problem solved .. got the pipe on , VERY close , there is zero clearance , but its ok now ...
Sometimes all you gotta do is just walk away from it for a few minutes.
cool . glad you got it figured out
sometimes you just need a bigger hammer :) |
lmao !!
© 2024 MH Sub I, LLC dba Internet Brands
