progressive not so drop-ins
i was thinking that the progressive drop ins were going to be a 30 to 40 minute just like they said on there web site, but not so much, you have to remove the forks the get the cap off to remove springs. and it take atleast 30 minutes to drop the forks out and then you have to put the new springs in. i cut the pvc down a 1/2 inch like they said the max was and i wish i would have cut alittle more off now and went alittle lower. but i don't think i want to take everything apart now. the whole job ended up taking me 1 hour 45 min. wasn't to hard just misleading when they tell you it will only take you 30 min with basic hand tools. you will need a strap wrench or a "soft" vise. i'll get some pics up tomorrow afer i get the bike off the motorcycle jack from changing all the oils
Yeah, they are not "model specific" in the literature, when they make that claim. On Dynas, I think the nut to access the top of the forks is readily accessible, so no removing the forks for them. Softails are a different story, but are VERY WORTH IT when you get the desired result using the drop in kit. Much quicker than the "old way" that Progressive had us doing it!
Yes you can. I always put the bike on a bike jack, and put a floorjack under the front wheel. Take the caps off the top tree and loosen the pinch bolts on the bottom tree. At first just lower the forks about 3/4 of an inch, this allows you to loosen the fork tube caps without them flying across the room from the spring pressure. Then lower the forks a couple of inches...the springs will come out thru the hole in top tree. Assembly is easy because of the shorter springs. Watch your brake hose. You could probably do your second set in 30 minutes.
4" pvc is what progressive says... You can cut it down to 3.5" BUT you have to change the fork oil to something heavier it'll be stiffer but so that you won't bottom out.
I got -2 tube so I had to cut mine down even more just to thread them up. I think I cut mine to 3.25" but when Ibreal it down again I'm gonna cut it down to 2.75" For me I'm running SE extra heavy racing oil and it is stiff.
