A couple of Fatboy Lo Questions
Hi everyone, picked up a Fatboy Lo a few months ago. my 4th Harley and loving the new bike.
Not a lot of mods so far - added some black 1.75 Rush slip-ons, the 4" HD risers, black levers, relo kit and detachable backrest and a windshield for longer trips.
Had a couple of questions for other FB riders, I ride the mountains a lot and was wondering if I can swap out the shorter FB LO shocks for standard FB ones to get a little more clearance without any modification (I think it brings the bike up an inch? or so)
Also, mixed feelings about the satin engine covers - would a set of earlier nighttrain covers fit on a 2011 or do I need to see my powdercoater?
Finally - my sig pic of my FBL shows up under my user CP but not here, do you have to have a certain number of posts for your sig to be visible?
Thanks!
Thanks!
I have no FB lo info for you... But use this info from Terry for your sig pic
Make Sure you have gone to your "USER CP" (blue bar,left side at the top of the forum) and then click on "Edit Options" and scroll all the way to the bottom and use the drop down to change from "Basic Editor" to "Standard Editor." This will allow you to "Insert" your photo into your Sig.
While you are in "Edit Options" you can change your time and change the Forum Defaults so you can see more threads and posts. You can also click on the box to allow the PM system to notify you when you have a new pm (pop up).
Terry
Terry
I don't think that's it and I did set my edit settings from advanced to standard.
The pic shows up just fine on the sig edit page and fits the specs listed on the CP-sig page.
I think something else must be going on..maybe I don't have enough posts to show a sig pic?
Cool, I know a lot of folks like lower shocks with standard FBs so I could probably work up a trade with my shorties if they're compatible .
Appreciate it.
Appreciate it.
