Will 2008 FLSTF Tin set Fit a 2007 FLSTF
I checked the P/N's and the fenders are the same but the tank comes up with a different number. Not sure why, I was more thinking the front fender might be different due to the offset wheel.
You can go here and check for yourself: http://partsfinder.onlinemicrofiche....m_oem/hdmc.asp
Gives you the HD P/N when you send the item to the cart.
Edit:
Googled the question and found that "It may bolt on...but the 08s have a newer fuel pump set up ...they mount totally different in the 08s" and found similar answers elsewhere. Read more: http://www.justanswer.com/motorcycle...#ixzz1LybwTpYS
I'm sure someone here has done it and will expand on this.
Edit:
Twinrider
07-17-2008 06:53 AM
