Free pipes!!
Sorry I really don't have, but what I can say is the 2012 Pipes are different for the 103ci engine. The o2 sensor are slighty bigger, but I heard there are adaptors that you can purchases and it will allow you to use your 2012 o2 sensor in those older pipes. If you check the V&H website I think they tell you the size differences between the 2 o2 sensor. I believed one 12mm and the other 14mm.. Sorry Don't quote me this, but it was I heard. Sorry I'm not really much help.
on my 2010 Lo, 96ci, I'm using a set of pipes from a 2000 Night Train, 95" carb'd.. they'll all line up fine.. the difference is the O2 sensors.. carb'd bikes don't have them. The 96" i have i think uses 18mm O2 sensors, and 2012+'s have 12mm O2 sensors..
Now here's the kicker, and how I made the pipes for a carb'd bike work on my EFI bike.. if you run a Power Commander, the directions clearly state to plug the O2 sensors and eliminate them from the ECM.. So.. that's 1 way to do it (if the pipes have O2 sensor ports)..
The other is to buy the O2 sensor adapter kit:
http://sales.nightrider.com/12mm-O2-...-Kit_p_22.html
https://www.denniskirk.com/o2-sensor...t.p4405200.prd
