4" compact size Air Cleaner for Softail, any one used it?
Hi I was looking for an after market air cleaner for my 2013 Slim, I found this 4" compact size air cleaner, I wondered if any one used it, any comments ? Thanks
http://item.mobileweb.ebay.com/viewi...d=251219216325
Received 3,953 Likes
They look good, and your bike will run with it, but it will be starving for air at high RPM heavy throttle. Simply will not breathe enough on a Twin Cam. The 4" will work adequately on a Sportster.
__________________
Kevin
Gear Up & Ride in! DK Custom 4th Annual Open House, June 8th. 🏍️ Click HERE For The Lowdown.
DKCustomProducts.com
Kevin
That is a Figure Engineering TC-4, I have a TC-5 (5 inch) on mine and I am making 90ish HP on a 98CI kit with a cam.
The TC-5 is also fairly compact if that is what you are looking for. It doesn't have a big cover around it like allot of A/C's
The quality is top notch and the breather feature works well without making a mess or using hose.
