ShotGun Shock Problem - Video Included!!!
Any ideas? It just started this today...
http://www.youtube.com/watch?v=NjyH8...ature=youtu.be
Something is rubbing and I am lost! I appreciate any feedback!
Once you dump all the air out (both switches down) it can take it a bit to come up and it may not be smooth.
Raise the bike all the way up with the compressor (both switches up). Then lower the bike all the way down with the compressor (raise/lower switch down). Then use the raise/lower switch to raise the bike. This should raise the bike quickly and smoothly. Try this and see what happens.
Thanks for the help, guys!
Did it make any noise before the Shotgun was installed? I don't know why a bushing only made noise after you put the Shotgun on there. JD's the man and I am sure between him and a few knowledgeable guys on here will get you fixed up in no time flat. It's an awesome mod and as soon as you get the kinks worked out of it you are in store for a ton of fun. Keep us posted on the fix so all those who come after you has someone to help them out. My install and use since then has been slicker than snot, no problems at all, none, zero.
