How to get sticky tape or adhesive off windshield?
I bought an OEM 16" Harley Quick Release Windshield off eBay (because I got a great deal on it) and plan on just using it for longer trips.
There are two adhesive strips or tape on the right side (looking at the pic below) and they would be on the left side if you were sitting on the bike.
What is the best way to get those off without scratching the windshield all up? WD40 and dental floss maybe?
Here it is... got it for $200, which isn't too shabby considering it is like brand new and the quick release clamps are $200 by themselves.
I've used WD-40 for stuff like that with fair results. (They look like the Velcro style strips for EZ Pass modules.) Just be careful with scraping of any kind. The windshield has a coating on it that can be scratched. I also found out the hard way that the coating doesn't like Windex much either. It will cause the coating to turn a little cloudy.
The windshield looks like the same kind that I have, including the clamps.
I assume the best thing to use to clean these windshields is water and a microfiber towel?
How do you like yours? Any buffeting? I almost bought the larger one (19" over the headlight) but I would be looking through it since I am 5'10". It seems the 16" will be perfect.
After I got to thinking maybe you should forgo the alcohol, not sure what your shield is made of. I clean mine with carwash & warm water for a throught cleaning, in between I use Clearview shields cleaner & polish, works great, takes bugs, dirt, off, leaves it clean as a whistle. When I clean it I use straight up and down strokes to avoid swirls.
