Samson True Dual exhaust
I live in Texas and the heat of the pipes doesn't bother me, even in the summer. Regardless, there are measures you can take to mitigate this:
1. Captain Itch crotch cooler
2. Ceramic coat the pipes
To start, I'm no exhaust expert. That being said I have searched this topic. I like the look of dual myself. Motown is right. Do a search. Plenty of good reading about those pipes. The reason this dealership is against is because they do take some of the power away. I've read that on here. I don't know what the difference would be between them and the ones you have now but if you had a good 2 into 1 set you would for sure feel a difference. I have read that on here. As far as application. I'm sure that have a set that will fit your bike.
I lost a little going to the Samsons from my Python 2 into 1 pipe but I suspect they would be a tad better going from stock to the Samsons. My motor is not stock though so that is what keeps it in the game. I also need a Dyno but I am waiting for after my headwork is done this winter. It isn't enough to bother me though as I just cruise. As for the heat issue? I got my 3 head pipes ceramic coated. There is much less heat coming off of the pipes and they still look brand new because there is no blueing going on under the heat shields. That ran me 125.00 and I am so glad I got it done.
What you lose in performance, you more than make up for in style. A programmer or Xied's fix most associated problems with running true duals. Never had a heat problem. My only warning is that they should have "remove before flight" flags as I've hit into them with my ankles a few times in the garage!
