Rivera Primo Game Changer
Item has been sold, thank you for your interest
Rivera Primo Game Changer Compensator Sprocket Kit P/N 1066-0050. Package was opened to mic the inside of hub, never installed. $150 + Shipping
Reduces the gear ratio from the stock 1.36 to a stouter, better pulling ratio of 1.44
• Kit includes everything you will need to convert your O.E. compensator assembly to one that will enable you to pull better on the straight-away and steep inclines
• Must be used with the 2011 and later compensator assembly. Earlier models must be upgraded to the newer compensator
• Includes a 32 tooth comp sprocket, and spacer for the O.E. chain adjuster plus complete instructions
http://www.riveraengineering.com/Game-Changer.pdf
