Crossbones Pictures
  #361
Old 05-27-2009, 07:10 AM
vjsports's Avatar
vjsports
vjsports is offline
Default Looking for new handlebars
Still undecided on which bars to get. i do like Zacharia 11, are they beach bars?
  #362
Old 05-27-2009, 07:23 AM
Zacharia_11's Avatar
Zacharia_11
Zacharia_11 is offline
Nah, the are Flanders BadBoy Bars.
They are also mounted on 4 inch risers off the 95-97 BadBoys.
  #363
Old 05-27-2009, 10:01 AM
Flying Hog's Avatar
Flying Hog
Flying Hog is offline
Got my custom derby cover from Don at Etchings by Pig. Also, re-located the headlight to the lower shock bolt with the RSD Vintage headlight kit for an even more retro look. I am getting real happy with this skooter!
  #364
Old 05-29-2009, 05:01 AM
jisham's Avatar
jisham
jisham is offline
The headlight relocation looks great! How easy is it to install?
  #365
Old 05-30-2009, 07:51 AM
Flying Hog's Avatar
Flying Hog
Very simple 10 minute install.
Two ways to get it done, simple and really simple. Remove the headlight bracket from current location, secured with a single allen type bolt. If you have a lift available, you simply lift the bike to remove weight from the front wheel. This unloads the shock. Then remove the lower shock bolt and install the light with the RSD bolt and bracket.
That is the really simple method and was not used by me because my wife's Sportster was utilizing my lift. So I improvised. I took a run of the mill ratcheted loading strap and wrapped it around the top of the spring assembly and the spring fork. Then ratchet the thing down until you "lock in" the compression that exists on the shock. At that point, crack the lower shock bolt loose and it should move freely within the shock mount. This will confirm for you that you can go ahead and pull the bolt.
You will need to cut a few nylon tie-down straps to allow re-routing of the electrical, so have a few medium size black ones available.
$89 and 10 minutes, not bad all in all.
  #366
Old 05-30-2009, 07:56 PM
jisham's Avatar
jisham
jisham is offline
Does sound easy. Thanks for the info.!
  #367
Old 06-01-2009, 10:48 AM
White Guy's Avatar
White Guy
White Guy is offline
I installed the RSD mount while the bike was on the jiffy stand. The shock stayed in place with no problems.
  #368
Old 06-01-2009, 07:21 PM
bigcajun's Avatar
bigcajun
bigcajun is offline
white guy i like how you have the headlight mounted on yours. hadnt thought about doing it like that. looks good.
  #369
Old 06-01-2009, 09:34 PM
vjsports's Avatar
vjsports
vjsports is offline
Default RSD rear fender white guys bike
hey white guy, i love the fender, but is there anyway the fender could be closer to the tire. i seen some other ones and they seemed closer.Name:  8fbab3e7.jpg
  #370
Old 06-02-2009, 05:26 AM
Flying Hog's Avatar
Flying Hog
Well there you go, now 3 ways to go. Easy, real easy, and so easy a caveman could do it.
FH
Quick Reply: Crossbones Pictures
