Measuring shock length
Old 10-16-2014, 08:35 PM
Traxxtar's Avatar
Traxxtar
Traxxtar is offline
Question Measuring shock length
When measuring rear shock length, do you measure from the center of the mount holes or from the absolute top and bottom of the entire shock?
Mine are 11.5 from center eye to center eye, so I'd like to go a big longer but wanted to be sure.
Thanks!
Old 10-16-2014, 08:37 PM
2500hdon37s's Avatar
2500hdon37s
2500hdon37s is offline
Received 1,550 Likes on 668 Posts
Center of the eye to center of the eye. With the shock fully extended, like with the bike on a lift or similar.
Old 10-16-2014, 08:42 PM
Scuba10jdl's Avatar
Scuba10jdl
Scuba10jdl is offline
OEM shocks are center-to-center at full extended length. This is essentially the same as when they are sitting unbolted save a few tenths of a millimeter.
When ordering new shocks, go with 12.5" or above. Most companies use this as the point where the spring rate changes from the short travel to long travel (and accompanying damping force changes), which leads to a much better ride.
Short dampers are only for looks. The best range for Sportsters is 12.5" to 14.5" dampers. Above or below that is a design compromise when you consider our frame and swingarm setups.
My personal choice would be 13"-14".
Old 10-16-2014, 08:52 PM
1200Cdriver's Avatar
1200Cdriver
1200Cdriver is offline
Smile
Since the shocks are at approximately a 45 degree angle to the swing arm the bike will only be raised about half of the additional length, give or take a little. More or less. This is how my 1200 C sits with 13.5" Progressives 440s on the rear.
Old 10-19-2014, 07:44 PM
Traxxtar's Avatar
Traxxtar
Traxxtar is offline
Thanks guys! Just looking at possible winter mods and the rear shocks, as well as the VERY soft front springs might need some attention.
slowrollin
04-06-2014 08:26 PM
Shawnmmx
04-23-2013 06:34 PM
msatow
Touring Parts
03-26-2012 04:13 PM
nebrown1
Shovelhead
02-24-2012 05:49 PM
pearlsporty
05-28-2008 07:25 AM
Quick Reply: Measuring shock length
