Should I Be Concerned?
RE: Should I Be Concerned?
IMO, the best thing to do is not winterize your bike, unless is it going to sit for a very long time (or you don't have access to it, where it is stored). All the bikes I have ever owned I would just go out to the garage and run them for about 20 minutes every week or so during the winter months. This keeps everything in the engine lubed up and the battery charged too. When you drain your gas tankyou run into the problem of it get rusted insideand the trickle charger has to watched very close, also. It is much less of a headache to just runit every week throughout the few months that you won't be riding.
A question with regards to my original question. I have more fresh oil available andam nowthinking I will change it this week.... so, should I run the engine justlong enough to have the oil that'sin it now return to the oil tank againand getthat oilwarm before changing so it will flow out well and completelydrain from the system? I'm assuming this isthe wayI should do it?
ORIGINAL: IronLegend
If you want to change the oil go ahead but since you're in Canada (cold chit place) I would warm the oil before draining it so it flows easier. If the milky color is bad enough to make it look like coffee w/cream then change it.
It's just my opinion but if you're running syn oil, I would change it at the start of the season instead of the end. New oil just sitting in the tank & crankcase for 6 months doesn't offer any more protection for the motor. my .02
the factory says to change the oil and filter before you take off after storage. it's a cheap deal for peace of mind. i'd hate to spend that time on the side of the road, waiting for the tow truck, kicking myself in the butt. i'm glad we can ride year round in texas.
Personally, i am with LazyBoy.
Here in California, we dont winterize, but I would change it for peace of mind. Maybe run it for a minute to get the oil flowing, then drain, and replace. You wont get it all out, but you can always change it again. Its cheap insurance.
[/align][/align]
[/align]
By the way, if anyone tells you it's too difficult to drain oil when it's cold, ask them if they warm up their quarts of oil first before they pour them into their bike.
Cold oil will come out of your bike just as easily as it will come out of a quart bottle.
Trust me, don't start the bike until you drain the contaminated oil out of it first and replace it.
ORIGINAL: Zeb
A question with regards to my original question. I have more fresh oil available and am now thinking I will change it this week.... so, should I run the engine just long enough to have the oil that's in it now return to the oil tank again and get that oil warm before changing so it will flow out well and completely drain from the system? I'm assuming this is the way I should do it?
Also, it is recommended that if you want to change the oil you should get it up to operating temperature. By the time you get the oil to operating temperature any moisture that was in the oil will have evaporated and you will be draining good oil.
You can decide to drain the oil cold without running the engine, but anything that has sunk down into the engine is not going to come out without you cranking the motor and it won't drain as well.
