08 heads on earlier model
Old 12-22-2014, 12:33 PM
akanorth's Avatar
akanorth
akanorth is offline
Stage III
Default 08 heads on earlier model
I have an 08 custom Sportster with a bad crankcase housing. I see a lot of older model engines on ebay. I was wondering if I could put my efi system on
say an 06 model that that was carbureted? or can I swap my heads to make it work?
Old 12-22-2014, 08:15 PM
Scuba10jdl's Avatar
Scuba10jdl
Scuba10jdl is offline
Unfortunately, due to a difference with the EFI throttle body, the carbureted heads cannot be used with EFI without significant machining. You can put EFI heads on to a carb, but not the other way around like you want to.
You're stuck with the 07+ heads. Keep in mind that 1200 vs 833 heads are different for chamber size, so you need to match that if you aren't doing other motorwork or machining.
Big Money
Engine Mechanical Topics
04-19-2015 06:38 AM
maddghost
03-21-2013 06:11 PM
jefftc88
Exhaust System Topics
12-14-2012 05:19 PM
74XLH 08FXSTC
03-24-2008 05:31 PM
Mike NY
03-05-2008 08:18 PM
Quick Reply: 08 heads on earlier model
