Wrapped my pipes ... Pics inside
I decided long ago I liked this look and finally had the time to get it done. I know some guys only do the upper part of the pipe but I like the look of the whole thing and going over the heat shields made the flow nice IMO. I went with the DEI titanium wrap for the color and for the fact that it installs way easier than traditional fiberglass stuff. Plus it gets great reviews at every corner. Got my delivery from Amazon yesterday. It was muuuuuch cheaper there than anywhere else plus I have prime so it was a no brainer. I got 2 25' foot rolls of the 2" wide wrap.
2 rolls were perfect for my pipes' length. I imagine if you had short shots or similarly length'd pipes you could get away with 1 roll. Other things worth nothing. I wrapped over the heat shields to create a beefier look. Decided to do that after watching about 20 how to guides on YouTube.
I started from the exhaust opening and worked my way back up to the motor end after removing the exhaust. Having never taken off the pipes before it took me 30 minutes, if I had to take them off again, I'd be done in 15 minutes. I forgot the proper metal zip ties at the store so I used plastic ones for now.
The hardest part honestly was being patient and holding it tight. As I went I applied zips because I was working alone it made it easier to give my hands a rest.
Here's two pictures with the first one done. I'll post the final setup tomorrow after the metal clamps go on.
I just did the same thing last weekend, but I took off the heat shields. And yes, they do help in shielding the heat from the rider and also helps in 'pulling' the heat out of the engine. I know this from the increased blueing closer to the exhaust. It also helps with the tinny soung, taking it out completely. I really like this mod.
OP; looks good and agree w/PTSDBob on the shields...pretty much anything under your wrap is susceptible to impact from the wrap and/or rust so, if/when you elect to unwrap, you'll be swapping the entire exhaust. It's just something to consider. That's not a bad thing as I change my looks quite often, based on new products and my overall likes/dislikes. Again, good job on the wrap and sounds like a great product too.
For others, I've seen wrapped pipes rust in one season and some last for years...depends on the quality (wrap/pipes) and riding elements. Either way - it's a great look.
Seems like you have a pretty good idea on this stuff so let me ask... Since I left the heat shields on, wouldn't that in theory act as a buffer to the actual pipe and any potential damage that could occur? ... Or would it expedite the process because the heat barrier now became even more thick?
