883 Running Lights
883 Running Lights
The front turn signal lights on my 883 also function as running lights. The rear signal lights don't; they only work as turn signals. But I think I've seen photos and videos of 883s showing the rears working as running lights as well.
Is this the result of the owners' mods?Or is it about differences between specs for different countries? (I live in Canada.)
Thanks!
Thanks!
Older models are only brake/turn lights. Newer models are brake/turn/run lights since they have done away with the center brake light.
You can get a module from aftermarket companies that will convert your lights to run/turn/brake lights as well. Just be aware it will increase your electrical draw leaving you less room for electrical accessories.
Ah, must be the HDI rules. I bet you can get the same style module as the older domestic US models to turn your turn signals in to run and brakes.
My ex roommate had one of those and the visibility/brightness is a lot better than my single tail light. I just have no room left for the module!
you need a running convertor like this. It is from hd for my 2008 sportster
http://www.harley-davidson.com/store...FYdFaQodi0kCRQ
