2009 Nightster spudder/jerking Cruising
I have an '09 Nightster 1200, V&H VO2 naked intake, V&H Short Shots Staggered Exhaust, V&H FuelPak with "proper Map" Mechanic confirmed no vaccum leaks exhaust is sealed etc. When cruising in any gear any speed except cruising at like 70-75. I get a spudder/studder as if either a plug isnt firing right, jets gummed up (they arent) or throttle isnt working right. But when I can throttle out and accel right out of it. anyone else with this issue, and if so what fixed it. I saw 1 guy said something similar was his ET sensor?
Received 2,191 Likes
This issue could be many things and I don't think the internet is going to help you as it (we) would just suggest throwing parts on.
Your bike is modified.
Suspect would be the fuel pack and its wiring or intake.
You need to duplicate the issue.
It could well be ignition from your description and the voltage regulator seems to be a common failure for example. Coils, sparkplugs wires and so on.
It could well be fuel.
Dirty fuel lines, injectors, filters. Carbon build up in combustion chamber causing a ping hence the Seafoam mentioned above.
Plug reader doesn't seem viable as this shudder is intermittent so yes their look is an average and OK.
Duplicate the issue at a shop so you can trace it is the first step IMO. Good luck
Used the Lucas ethanol cleaner once and the bike ran like crap. Unfortunately I added it to my VROD also at the same time and the same thing happened and I even got the check engine light. Be careful with those additives/cleaners. Took two tank fulls to clean it up.
Try a different map (close to the one you have) with your FuelPak and see if you get any changes. Your map could have gotten corrupted.
