DK Customs Rocker Lockers?
I've been looking around the DK Customs site and noticed the rocker lockers. I am curious if anyone has installed these and how much of a difference they make in the tapping noise of the rockers? Does anyone have a comparison video of the noise before and after install? I am very interested in these because I can't stand the sound coming from my engine. Am I alone here? It always worries me that something is wrong since I had a pushrod come out of adjustment right after install of the 88 ci kit. Any experience with these you wish to share is appreciated.
Trying to do a before and after video has been a bit elusive, our ears can pick up so much more than the video cameras are capable of capturing!
This video is about the best example of the tick/tap sound, you can hear it right at the beginning:
The witness marks on the bolts tell the tale of the amount of movement and play that is creating the sound you're hearing:
The Rocker Lockers eliminate the gap, locking the shaft from turning and striking the bolt and eliminating that annoying tick. The Rocker Lockers will also center the inner rocker cover so that it is always located in the same position eliminating the different wear patterns on the rocker arm/valve and give a better alignment of the pushrod in the holes.
You didn't mention your year of Sportster but the 86-06 Sportster Rocker Lockers and the Sportster Models 2007-Up are available to end that top end ticking!
The Rocker Lockers are tapered so that they lock themselves in and wedge the bolt and shaft in place.
__________________
www.DKCustom.com
662-252-8828 Voice
662-420-4891 Text & Voice
Support@DKCustomProducts.com
www.DKCustom.com
662-252-8828 Voice
I understand the issue with capturing the sound on video. I am definitely going to give them a try. It seems to be louder to me since I had the 88 ci upgrade installed. Could just be me but if these will at least reduce the noise a bit I want to try them. It doesn't seem to be too difficult to install these. What is the estimated install time?
It because of the sound level difference. Our ears can hear a broad range of sound volume levels, but most capture devices cannot. The best chance would most likely be to have the sound capturing near the front left side of the tank, so it is close-ish to the rockers and far-ish from the muffler sound direction.
I'm not a sound tech so that's about the best advice I can give. When I install mine eventually I'll try to capture some audio, but it's going to be a few months before I do that.
Received 3,963 Likes
Yes, we have 4 different models of Rocker Lockers.
You can see them all at this LINK.
Twin Cam
Big Twin Evo
07-Up Sportster
1986-2006 Sportster
Twin Cam
Big Twin Evo
07-Up Sportster
1986-2006 Sportster
__________________
Kevin
Gear Up & Ride in! DK Custom 4th Annual Open House, June 8th. 🏍️ Click HERE For The Lowdown.
Kevin
