Fat Boy solid rear wheel on Sportster
Hey guys, I'm looking to get away from wire spoke wheels so I can run tubeless. On the rear, I want to run a Fat Boy wheel. I've seen it done before, and I like the look. On a 2000 Sportster, what year range would I be looking at for the donor wheel? Were there significant changes? I have a line on a wheel from a 2008 right now.
Received 2,189 Likes
start here:
full chart here: http://ridewrightwheels.com/pages/mo...-fitment-chart
then look into axle sizes etc...
then ask this guy whayt he did, lol:
http://xlforum.net/vbportal/forums/s...d.php?t=333368
Cammed (07-13-2016)
spoke wheel weight can surprise you....the tube adds weight. some spoke wheels are tubeless too. My fatboy came with spokes from the previous owner, I don't know if they're tube or tubeless. The valve stem looks like an aftermarket chrome one that has a nut holding it. I want to change them eventually just because I don't like to clean spoke wheels.
Technically, a 2003-later softail (including fatboy) 16x3 has a slightly different offset than all other 16x3 Rears of that time frame. Look for a 2000-2002 Fatboy wheel or any 16x3 solid from a 2000-2007 sportster for same exact fit.
With that being said, most people don't know that there is a difference (that's what you'll see on ebay) or how to determine which is which "They all look the same". Well they don't all look the same when you know the key.
Top: 2000-02 Softail (can also be used on Sportsters,Dynas, and Touring) using the standard offset used by all those 16x3 harley wheels
Bottom: 2003-later Softail 16x3 (not the even later wide-hub 16x3) Notice the "unique" machining around the Hub (Brake Disc Side). That's your visual identifier
Cammed (07-13-2016)
