Valve Clatter - How much is normal?
Received 1,522 Likes
The tapping may be normal, but if it does not feel like it is running right, you may have deeper concern. Test ride a few Sportsters. Let a fellow sportster owner test ride yours. gather info from those around you that ride Sportsters. Join a local bike club and listen to their suggestions before tearing into the engine.
We would only be guessing at what it might be.
It is easy to say, just ride it (and that might be the best advice)
But, if you have a bad cam, bent push rod, damaged lifter or roller, you may be damaging your engine.
Get a motor stethoscope and pin point the noise.
Note whether it is louder when cold or once the engine has warmed up.
Get rid of the fear and then enjoy the ride.
If you are questioning your engine, you need to have answers.
Earplugs are not the answer, but knowing everything is normal and the engine is okay will make your enjoyment that much better.
Let us know what you find out, but do not just have it taken apart to have peace of mind.
Explore the nature of the beast for yourself with a few test rides and take advice from those that are on hand to experience exactly what you are hearing and feeling from the engine.
Sportsters do have engine noises that others do not have.
All will have those noises.
You my find that none have the noises you are experiencing.
If that is the case, then you may have to consider your options.
Received 4,618 Likes
Sound means different things to different folks, I'd have to hear it compared to mine to really say one way or the other. If you want to hear a really noisy motor, listen to a Ural, my sportsters sound so quiet after riding that thing.
I get that calm clattering like was mentioned yyup
OK Ive pulled my top front end off. to check for slop in main ...at the rod end (piston) rod play is tenth ..... I haven't measured side to side play yet ....push and pulled up and down don't feel any play .....but I didn't expect the rod play at the top ...... from what ive read it seams fine...... I pulled the lifters cleaned one out then filled it back up with oil.....I have changed lifters once already thinking it was a bad lifter ...... bike only has 5000 on it Ive changed oils heavier weight synthetic -dino .......in the end the clatter is still there after it gets fully warmed up just later with the heavier oils...... I have notice my rocker pins seam to have the shiny spots where the pin might be rotating making noise so I ordered rocker locks...... piston looks virtually new , surprised at the carbon build up..... skirts look good piston cylinder looks great ......cleaned it all up waiting on gasket set to show up ....
one cylinder at a time for me . amazed at the noise this thing makes took to the dealer and they say it sounds fine ..... ive listened to other sportsters and they do not have this claking noise...... the sewing machine sound I can live with but this has driven me nuts. I have also pulled cam chest it was tight pulled the called out with the ..... should be fine ......
one note when we started the bike (hadn't been ran in over a year maybe 2) ......it had the clak LOUD then after it ran a little bit it softened to about half......
going thru the motions trying to find the culprit ....
I have a2008 fxstc also
1HD4CJM1X4K (01-24-2017)
Received 3,961 Likes
However, part of the top end noise can be reduced/eliminated with Rocker Lockers.
Below is a vid explaining how they work.
__________________
Kevin
Gear Up & Ride in! DK Custom 4th Annual Open House, June 8th. 🏍️ Click HERE For The Lowdown.
DKCustomProducts.com
Kevin
You need to confirm if you actually have a problem first! None of us can help you there, you need to visit either your dealer or a local indy and get an expert to listen to your bike. If you bought the bike new, then go to the dealer. If you do have a problem you also have a warranty!
