Gauge Relocate
Gauge Relocate
Guys who are running them, Whats the best set up/product for a sporty 48. Last thing on my list of things to do before spring time but just so overwhelmed by the different brands, prices, set ups.
Harley tried to sell me a joker machine one but said it would'nt work due to the 49mm fork on the 16+ 48s?
Pics if you gottem!
Edit- Looking to lower it to the lower left of the tank.
Pics if you gottem!
Received 2,189 Likes
Pics if you gottem!
Pics if you gottem!
relocate to where? Left, right, lower, tank, higher.... see what i mean?
Russty__ (02-09-2017)
Pics if you gottem!
Pics if you gottem!
Uses the mounting bolt from the tank. I can still clearly see up to about 60 mph which is perfect for Minnesota (there aren't a ton of roads over that). Totally clears my bars with "under-mounted" mirrors. I also picked up the Joker Machine top clamp to keep the dummy lights where they were.
My bike is different than yours ('04 883 with 3.3 gal tank), but I'd imagine it would sit pretty much the same.
Here is the kit I used:
Here is the link to my write up:
https://www.hdforums.com/forum/sport...elocate-2.html
One of the big factors on determining which kit to use, is do you want your gauge rotating with your forks or do you want your gauge to be fixed. Also, do you want the indicator lights to move with your gauge or top mounted. I chose top mounted indicator lights because that is where I want to look for turn signals and when finding Neutral. That is what works best for me. That is why I went with the Joker Machine top clamp w/indicators. I love the look of the side mount.
