fuel light and neutral light on my 2013 sportster 48 xl 1200 x
3. Neutral Switch Test
1. Disconnect the neutral switch [136].
2. Does the neutral lamp turn OFF?
a. Yes. Replace the neutral switch. (5157)
b. No. Go to Test 4.
4.TSM,TSSM or HFSM Test
1. Disconnect the TSM, TSSM or HFSM [30].
a. Yes. Replace the TSM, TSSM or HFSM. (6845)
b. No. Go to Test 5.
5. Neutral Switch Circuit Test
1. Disconnect the instruments [20].
2. Using the HARNESS CONNECTOR TEST KIT (Part
No. HD-41404) and a multimeter, test for continuity
between [20B] terminal 8 and ground.
3. Is continuity present?
a. Yes. Repair short to ground in (TN) wire. (5041)
b. No. Repair or replace the indicator harness. (5191)
NEUTRAL LAMP INOPERATIVE
PART NUMBER TOOL NAME
HD-41404 HARNESS CONNECTOR TEST KIT
Table 4-18. Neutral Lamp Inoperative Diagnostic Faults
POSSIBLE CAUSES
Neutral switch malfunction
Open ground circuit
Open neutral switch circuit
Indicator malfunction
1. Neutral Lamp Function Test
1. With the vehicle in neutral, turn IGN ON with the engine
OFF.
2. Does the neutral lamp illuminate?
a. Yes. Test for intermittent. See 1.3 DIAGNOSTICS
AND TROUBLESHOOTING, Wiggle Test.
b. No. Go to Test 2.
2. Neutral Switch Test
No. HD-41404), jump the (TN) wire to ground.
3. Does the neutral lamp turn ON?
b. No. Go to Test 3.
HOME
2013 Sportster Diagnostics: Instruments 4-17
POSSIBLE CAUSES
Open ground circuit
OFF.
HOME
DTC B1005
HD-42682 BREAKOUT BOX
HD-46601 BREAKOUT BOX ADAPTERS
Table 4-5. DTC B1005 Diagnostic Faults
POSSIBLE CAUSES
Open ground circuit
Short to voltage in fuel level sensor circuit
Open fuel level sensor circuit
Instrument malfunction
Fuel sender resistor assembly malfunction
1. Low Fuel Lamp Circuit Voltage Test
1. Disconnect the speedometer [39] (XL) or tachometer [108]
(XR).
2. Connect BREAKOUT BOX ADAPTERS (Part No. HD-
46601) to connector [39] (XL) or [108] (XR). Connect
BREAKOUT BOX (Part No. HD-42682) leaving the
speedometer [39A] or tachometer [108A] disconnected.
3. With IGN ON, test for voltage between breakout box terminal
9 and ground.
4. Is voltage present?
a. Yes. Repair short to voltage in (Y/W) wire.
2. Fuel Sender Resistor Assembly Test
1. Disconnect the fuel level sender resistor assembly [200].
2. Using HARNESS CONNECTOR TEST KIT (Part No. HD-
41404), measure resistance at [200A] between terminals
1 and 3.
3. Is resistance between 9600-10,400 Ohms?
a. Yes. Go to Test 3.
b. No. Replace the fuel sender resistor assembly.
3. Low Fuel Lamp Circuit Continuity Test
1. Test for continuity between breakout box terminal 9 and
fuel level sender resistor [200B] terminal 3.
2. Is continuity present?
a. Yes. Go to Test 4.
b. No. Repair open in (Y/W) wire.
4. Ground Circuit Continuity Test
1. Test for continuity between fuel level sender resistor [200B]
terminal 1 and ground.
a. Yes. Replace speedometer (XL) or tachometer (XR).
b. No. Repair open in (BK) wire between terminal 3 and
ground.
HOME
2013
POSSIBLE CAUSES
Open ground circuit
(XR).
9 and ground.
1 and 3.
ground.
HOME
2013
