Clutch issue???
Hello all,
I've had my first Harley for about 5 months now (2009 XL1200C) loving it! I'm having an issue with my shifter/clutch/transmission (I don't know). Sometimes while I'm stopped in first gear, with clutch all the way pulled in, the bike pulls forward slightly (sometimes not so slightly). It is also pretty much impossible to get the bike into neutral during this time as well. In order to get the bike in neutral I have to be rolling about 5 mph or turn the bike off. Any ideas how I can fix this? Is this a normal thing for Harleys? |
Sounds like you need a clutch adjustment
Is that something I could do with my limited mechanical experience? Prefer not paying for something I could do myself.
Originally Posted by Cutstavo
(Post 16430226)
What is happening at present is that your clutch is not freeing itself fully, when you pull the lever in, the plates are dragging a little, which makes selecting gears and especially neutral difficult. You can however select neutral while still rolling, rather than waiting until you stop, which may help in the short term. |
Depending on previous service interval it may be a good time for a drain/replace primary fluid service, as well as a clutch adjustment.
All is easily done if you can follow a manual. Search Delboy on Youtube also, He has several vids to show you what to do. |
Thanks!
What's with the bike pulling forward while stopped? It's fairly hit or miss and doesn't do it all the time. |
Originally Posted by grbrown
(Post 16430298)
Yes. You will require a few tools and I recommend you get a factory service manual, available from your local friendly dealer, which spells out all you need to know. There is also a Sticky in the Tech Primary section, on adjusting your clutch.
Adjust the clutch cable at the adjuster on the cable itself. If it still does it, pull the derby and adjust the clutch itself.
I appreciate all the advice. I'll see what I can do when I get home from work.
and/or |
© 2024 MH Sub I, LLC dba Internet Brands
