Mine is an 06 XLR1200. The battery shows 13.5 volts. When I put it back in absolutely nothing happens, no lights, nothing. I pulled the battery back out and noticed a hot terminal on neg side again. I then hooked battery charger to cables, turned it to 10 amp charge, and I could hear loud buzz coming from the starter I think. I have no idea what is going on.
I have had battery's do that ---- what you need to do is charge the battery then load test it off of the bike . What sometimes happens on a bad battery is as soon as you put a load on the batt it dies
A lot of auto stores can do that test
So, I left battery sitting on cover this time. All hooked up, turn key on, nothing. Within 5 minutes terminal was hot again. I think there is enough positive cable to turn battery around,( I put it in the same way it was when I bought the bike ) but that is not my problem at this time.
I connected the positive cable first, then the negative cable. Would a battery short out overnight? I've been riding it all summer. I have the owners manual, no service manual.
