Flush gas cap for 2017 Iron
I've bought two flush caps for my Iron so far and neither fit.
There is a metal tube sticking up in the fill hole that blocks the gas cap from screwing in all the way.
Can I trim that tube down so the gas cap will screw in all the way?
Try removing the screw and see if the added clearance is enough for you.
What year is yours?
I bought mine new and it came this way
Something to do with California emissions maybe? I know on my bike once I filled it up sitting straight up and when I rolled it out onto the drive and put it on the sidestand I had a small puddle of gas on the driveway. It was dripping out of the vent hose, apparently California doesn't want that to happen. Wonder how a California tank vents if over filled?
I wonder if HD puts the plug in the vent tube to prevent anything getting in the tube during manufacturing/assembly, and is supposed to be removed when the bike is fully assembled? But it doesn't explain how the bike would run for more than a few minutes with no vent since it would start to form a vacuum in the tank.
