Made my 2013 883 a hardtail
Like I said, been there done that ....
but if you want a hardtail just go for a real hardtail frame instead of some struts way better looking.
I would recommend getting quality rigid struts if you're going to stay that style, I've seen the eBay cheap ones snap. DK Customs Beefy Struts are good and if you can find them, Biltwell made the thickest ones.
If you end up wanting slightly more cushion, Burly Slammer shocks will lower the rear 2.5" - 3".
For up to a 2" drop you can use steel lowering blocks with your stock shocks.
You can also lower the PSI a little on the rear tire for a little more cushion if you don't mind wearing it out a little faster.
I put 10k miles on my lowered Sporty last year, I ride it almost everyday. I'll be 45 in 2 weeks with a bad lower back and I am just fine riding with struts.
http://www.emd-part-usa.com/23-04-up-sportster
T.
Think Speed Merchant just resells the EMD products right ?
T.
T.
https://www.hdforums.com/forum/sport...cam-cover.html
I had Hammer Performance cut mine...
hth,
T.
You can also buy a pre-trimmed cover from Harley, its the "rail" series. https://www.harley-davidson.com/stor...gearcase-cover
