How long do official hd batteries last?
Old 05-16-2019, 12:25 AM
tnriverluver's Avatar
tnriverluver
tnriverluver is offline
If the battery has an 18 manufacture date Harley should replace it if it turns out to be bad.
Old 05-16-2019, 12:32 AM
hscic's Avatar
hscic
hscic is offline
As mentioned, check your connections.
Be careful using a charger, as opposed to a battery tender....there is a difference. A charger sends a constant charge without regard to what the battery needs so it can overcharge the battery. A battery tender or smart charger trickles charge over several hours and senses what the battery needs and stops charging when full. So be sure to get a battery tender, then you can leave it on your bike...and will charge if you have parasitic drain. And no, parasitic drain does not drain the battery in 10 mins, otherwise every time you stop for more than 10 mins, you will have a dead battery.
Recently, I have seen several new bikes out of the dealership with faulty batteries even after it has been charged so the owners had to replace the battery...and the dealership did not cover it under warranty.
Old 05-16-2019, 11:15 AM
83XLX's Avatar
83XLX
83XLX is offline
I typically get 6 or 7 years out of a Harley-branded AGM battery. I ride the bike enough that I rarely hook it up to a trickle charger.
Old 05-16-2019, 11:43 AM
show-n-go's Avatar
show-n-go
show-n-go is offline
My 2013 limited battery lasted 4 years and was still going strong when i sold the bike, My 2016 limited already has a new battery as of last spring. I always keep it on a tender when it's home. I think some batteries just aren't made right. My mower battery lasted 7 years having never been plugged into a tender, end of last fall I finally got power to my shed, hooked the mower up to a tender then this spring I had a dead battery.
Old 05-19-2019, 08:27 PM
Deucedog's Avatar
Deucedog
Deucedog is offline
My stock battery was replaced at 7+ years as preventative maintenance. I gave it to my neighbor for his riding mower. It was in that for at least 3 years. My bike is on a
15 year old Battery Tender Jr. any time I'm not riding it. The current battery is now 4 years old.
Old 05-22-2019, 09:33 PM
Geoo's Avatar
Geoo
Geoo is offline
Noco charger seems to have fixed my Harley battery. I ran the desulfate/stratification mode 4 times. After about 5 hours on each repair mode the notification light blinked indicating battery will not hold charge, but I put it back in the bike and 12 hours later the battery still starts the bike with no hesitation. Kinda wish I tried this before filling the new battery with the acid.
Derf_
04-20-2017 06:41 PM
c50plus
04-16-2015 11:47 PM
HighLiner
08-29-2012 02:37 PM
andyp
04-13-2012 03:42 PM
StreetGlider57
10-19-2010 07:41 AM
Quick Reply: How long do official hd batteries last?
