Changing Rim Size on 2004 Sportster 1200 Custom
Hi All! I am looking to purchase a 2004 Sportster 1200 Custom but am wondering if anyone knows/has experience changing the front rim from the standard 21", to the new style found on the 2019 Sportster 1200 Iron. A 19" and wide tire. Any details including part numbers would be appreciated. Very difficult to find any info on this. Thank you!
jessdarrigo (06-11-2019)
A 2019 uses different axle and bearing sizes from an 2004 so it would be much easier to install a 19" wheel from an earlier bike 2000-2007 (but double check that).
All the info you need is at http://partsfinder.onlinemicrofiche.....asp?make=hdmc
Compare part numbers for wheel bearings, spacers, axles, etc. to see what is compatible.
cacomly (06-11-2019)
Received 4,617 Likes
Make sure whatever you try to do that wheel, bearings and axle sizes match up, lot of differences through the years. Some info here might help - http://xlforum.net/forums/archive/in...t-1933117.html
I have experience but on a 2008 bike. The 2008 uses metric sized bearings.
Looking at H D shop you would purchase a wheel you like and then the correct fitting kit for the year of bike you have which contains the correct bearings and spacers.
Obviously if you get a wheel in the year range of your bike it will have the correct bearings but they are not hard to change.
SportsterHammer
05-14-2005 01:54 AM
