question about RPM's....
I am sure that HD would not provide information to every owner that would "wreck your motor" since they will fix said wrecked motors for free for 2 years and unlimited miles
On a 1200 Sportster at 45 mph in fifth gear is about 2100 rpms, an 883 is around 2400 rpm.
The HD suggested downshift speeds keep the rpms right around 2000 rpms, for shifts from 5 to 4th, 4th to 3rd and 3rd to 2nd.
I usually shift at these speeds (stock 1200), it makes the speedo into a gear indicator
If I drop below 50mph, I'll downshift to 4th, to third at 30 mph, second at 20 mph
1 - to - 2 20mph
2 - to - 3 30 mph
3 - to - 4 40 mph
4 - to - 5 50 mph
So far only about 37,000 miles with no engine damage!
1 - to - 2 20mph
2 - to - 3 30 mph
3 - to - 4 40 mph
4 - to - 5 50 mph
Pnut48 (06-16-2019)
For best performance and fuel mileage, keep it in the power curve. The bottom of that is 3200-3300 rpm. Why do think performance and fuel mileage is best between 3300 and 4000 rpm? Cuz that's what your motor wants. That's where it's happy. NOT at 2000rpm for God sakes. Anyone that has a clue about these motors knows that.
People over at The Sportster forums tried telling you that years ago Shanneba but apparently you think you know better. I would love to see the inside of your motor. Probably need a chisel to get the carbon off the pistons.
Just an FYI, THE HDI bikes are geared even higher. US 1200s have a 29 tooth front sprocket. HDI 1200s have a 30. I've been thinking about putting a 28 on.
Lugging the engine is an understatement. 2500rpm is lugging it. 2000 is killing it. The lowest i would hit 5th is 65mph and even then I sure wouldnt give it much throttle.
I'll cruise all day long in 4th on 60mph 2 lane and NEVER think about hitting 5th.
Pnut48 (06-16-2019)
Lugging the engine is an understatement. 2500rpm is lugging it. 2000 is killing it. The lowest i would hit 5th is 65mph and even then I sure wouldnt give much throttle.
Pnut48 (06-16-2019)
Shanneba does have point in so far as your owner's manual gives guidance on riding your bike. The manual goes on with, "The listed speeds are recommendations. Individual riding styles can determine gear change road speeds." and elsewhere it talks about not labouring the engine.
The manual is written for all models of a given year and possibly the 883 is quite happy at those speeds.
As mentioned a couple of times now HDI (UK) bikes are geared taller so my earliest pootling gear changes are spread progressively more from gear to gear and higher than the manual suggests.
Pnut48 (06-16-2019)
The owners manual tells you to put in too much oil too. Or carbs set up too lean. And this is the same Moco that had the timing too advanced and too early for how many years. The same MoCo that calls their SE cams performance cams. How 'bout their SE air cleaner. Or the new generation of SE slip ons. Common sense has too prevail. They have their own best interest with the EPA in mind not what's best for your motor
Are you running a stock setup? What is the actual spec of your bike?
My bike won't have it because it is geared higher. The manual is written for US bikes and is probably referring toward the 883.
Those speeds aren't even close and it doesn't take much for a normal person to realize this immediately. Try giving it throttle at 2000 rpms.
Pnut48 (06-16-2019)
IMO, the important thing is not to over think it. People fall into that trap with countersteering, unless you are taking corners/curves at a walking pace you are countersteering, you just don't realize it.
Same with shift points, don't over think it. If you can't accelerate smoothly, your in too high a gear. Better to keep it spinning faster as lugging it will literally beat an engine to death. After riding any bike for a while, when to upshift and downshift should come naturally without even having to think about it, you will just know.
