Ignition problems 2014 sporty-eight
Whats cookin'? Ive got a bum ignition. (Part key goes in) and im looking to not give the stealership $140. Has anyone wired up and after market 3 position ignition switch on a newer EFI sporty? Mines a 2014 forty-eight. Or know of any other means? Im worried they have some form of electronic stuff hidden in the housing or something? Or can i just run it old school?
On a CAN bus ignition it looks like the switch incorporates resistors. If you went aftermarket you would need to make sure it is for 2014 else it will almost certainly not work.
Not $140. When you order you should give the key or lock number and then you keep the same key I believe.
71400083 | New Castle Harley-Davidson (newcastlehd.com)
You could've used the forum's search function and found quite a bit of threads
about different ignition options....
Here's one:
https://www.hdforums.com/forum/sport...on-option.html
hth,
T.
Here's one:
hth,
T.
I was just offering an example - not implying that it would solve his particular
issue, but there is probably an existing thread that does...
T.
