clutch cable lube question
I find in the service manual on how to adjust the clutch cable, but I find nothing on lubing the cable., Ok maybe a dumb question, but I was always taught that the only dumb question is the one not asked. So How do you lube a clutch cable on a 06 1200C. My husband wont be home for 4 more months and I asked the dealer and they said to bring it in and they would take care of it for probaly $50.00 (YIKES)
RE: clutch cable lube question
Spray some WD-40 in the end of the cable and work the lever a few times, repeat a few times. No need to loosen anything or adjust anything unless your cable is alreay out of adjustment.
Their are "special " lubes avail., but WD has workd for me for the last 25 or so years.
Here is a link with a video that makes it really simple.
http://www.expertvillage.com/interviews/motorcycle-maintenance.htm\
I use Tri-Flow, it's a teflon based aerosol lube. It's perfect for cable lube, and last much longer than wd-40. Not to mention tri-flow does a much better job of repelling dirt and moisture as well. WD-40 attracts dirt and things can get mucky after a while. Although in a pinch I'll used WD-40 if it's the only thing I have around, but I still prefer Tri-Flow if I have some around.
I hate when I get the bike back from service cause they lube the cables and the leak black crap all over me when I ride.It takes a good 100 miles or so before all the excess lube leaks out.I have ruined a couple of shirts with the stuff flying out of the cables.I know it's needed but it still sucks
Has anyone ever used TDL from PB? It goes on as a liquid, so I assume it would be a big help in getting down the cable housing, but it dries yet leaves the item lubricated. I use it all the time around the house in place of WD40, but have no idea how well it would work for a clutch cable.
