im thinkin about progressives
RE: im thinkin about progressives
Hogsport is correct on this one. The shock length is measured eye to eye, installed on the bike, wothout any load. The factory stock length for the 04up 1200C model is 11.75". The equivelent Progressive replacement length is 11.5"
I wouldn't recommend going shorter than 11" unless you want to accept a pretty rough ride. (Lack of shock travel) You might want to consider 1" lowering blocks instead & 11.5" Progressives.
I have some lowering blocks if any one wants some, I am thinking of getting some progressives but want to keep the same height just want to get a better ride and also looking at forks as keep bottoming out on them when I hit a hole,. any suggestions on what I need to do to help the forks and what size progressives needed for better ride...no bottoming out and keeping same height BTW I have a 2005 883 low
