Had my headlight apart today
I've had the same issue with my headlight as well. I've used windex a couple of times to remove the haze from the headlight reflector and it works well...temporarily. The haze returns after awhile. I'd be curious to know if there's a better fix than this. Maybe some of the automobile windshield anti-fog stuff?
The headlight lens and reflector are permanently attached to each other. The bulb comes out the back. Looks kind of like a short, fat bottle with the neck of the bottle being where the bulb fits. So the only way to access the inside of this "bottle" is by way of the hole where the bulb fits in. It is possible to get a finger or a dowel wrapped in a soft cloth into the hole to clean but to spray it with a clear coat would not work. Good suggestion otherwise.
