Mobile 1 Fully Synthetic 20W-50
Old 07-05-2009, 01:32 AM
SportyPig's Avatar
SportyPig
SportyPig is offline
Mobil-1 15W50 for me too. I ran Mobil-1 V-twin for about 15,000 miles, but cHarley and OFG convinced me that the Mobil-1 automotive was just as good. I get the 5 quart at Wally World for $23. Once I FINALLY got my local store to carry it.
57,000 miles, and no engine problems so far......except for leaking head gaskets.
Old 07-05-2009, 07:09 AM
Hitechluddite's Avatar
Hitechluddite
Hitechluddite is offline
One word of caution about the Mobil 1 15W50 if I remember right the "Advanced Formula" flavor of that they came out with not too far back changed the classification from SH to SJ or some such thing and lacks some of the anti-shearing agents of the older formula. (something I read in a bike rag somewhere...)
I've run Mobile 1 15 W 50 in my bikes since the early 90's and know that it outperforms dino oils and limits wear as the miles pile up. I used Bel Ray and changed religiously at 2500 miles in my 81 wing and at 110,000 miles it burned a quart every 2,000 miles. I ran Mobile 1 in my 83 Wing and changed it every 5,000 miles and after 204,000 miles I burned less than a quart every 5,000 miles. Same type engine same rider.
I tried Harley Syn 3 in my Sportster and went through more than a quart in 5,000 miles. So this time I went to Mobile 1 V-Twin and I'm a little under a quart at 4,400 miles this time plus I swear the engine was noticeably quieter with the Mobile 1.
I have toyed with the Rotella idea for the Sporty, If it came in higher viscosities I'd give it a shot.
Old 07-05-2009, 12:58 PM
Flatlander's Avatar
Flatlander
Flatlander is offline
Still paying too much for mobile 1 v-twin but the engine runs 10-15* cooler and is not as noisy as it was with Dino oil. May switch to the 15-50 mobile 1 next oil change.
Old 07-05-2009, 01:23 PM
cHarley's Avatar
cHarley
cHarley is offline
Molecular shearing is not a concern in the motor. Shearing is a concern in the tranny where gear meshing occurs and that's why running a Gear Oil, like Mobil-1 75w-90 which is designed to cope with shearing, is preferable to using a "motor oil" in the primary/tranny.
Old 07-05-2009, 04:10 PM
Hitechluddite
Sporty's share engine and Tranny oil, that is why I'm concerned about it. The primary is only the wet clutch.....
Old 07-05-2009, 04:21 PM
cHarley's Avatar
cHarley
cHarley is offline
Sorry, don't know where you're getting your information from but it's WRONG. The Sporty shares tranny & primary oil. The engine oil is separate. The tranny and primary are one common compartment.
Bad information is worse than no information.
Old 07-05-2009, 06:57 PM
xFreebirdx's Avatar
xFreebirdx
xFreebirdx is offline
Dude, you need to buy the service manual and if you already have bought it read it. There are only the two, 1: Motor oil, 2: gear, primary, clutch.
Old 07-06-2009, 08:38 AM
RATROD HOG's Avatar
RATROD HOG
RATROD HOG is offline
+3 come on man get your zhit together
Old 07-06-2009, 08:46 AM
labou1's Avatar
labou1
labou1 is offline
Default Mobil 1 20/50
I use it in both my 03 Sportster and my 08 FXDL. Wouldn't use nothen but.
Here is a link for some good prices.
http://www.amazon.com/Mobil-V-Twin-M...6223902&sr=8-1
Old 07-06-2009, 08:58 AM
Willie D's Avatar
Willie D
Willie D is offline
Thumbs up
Originally Posted by eazyrider
No difference to me. I now use Mobil 1 15w-50, way cheaper.
Yup, that's what I use. Also use Rotella 75w90 gear lube in the primary. shifts better and easier to find neutral.
JMHO
Quick Reply: Mobile 1 Fully Synthetic 20W-50
