Can you wheelie a stock '07 Nightster?
It should be pretty easy in SanFran streets.
First gear...rolling 10-15mph grab the gas hard then the clutch quickly before redline(or you'll over rev and smoke the tire or once the front end is up it will fall like a rock once the limiter kicks in). You need to know where your bike pulls hardest in its powerband. I couldn't have fun until I did Stage 1 upgrade and only have ***** enough for power wheelies cuz the balance point is nearly straight up.
My Buell XBscg should be a unicycle.
P.S. Sorry for instigating bad behavior...
I was following a Nighttrain coming out of a hard turn uphill, he got on it so I had to catch up. I got on it and it pulled up on me, I never let off. This was in second or third. Most likely second but I dont remember. Just about any bike can do it if it is not too heavy. I used to do it on a honda 500 all of the time. Until the throttle stuck and I wound up under a car. that ended my showing off.
You can only get em like a foot maybe 2 off the ground... But say bye bye to ur clutch... stock clutches suck nutties... I usually wait till I find intersections with a little hump in the middle then I use that for momentum.. But good luck... Get the screamin eagle clutch. that's what I got, and u can wheelie all day, Plus a K&N Intake (coned) and a stage one download.... Thunderheader.... Then ur having a time of ur life...
Clutch - 200 bucks.... filter =300 Bucks. Thunder header 650 bucks. Stage 1 download from Harley dealer = 200 bucks.... Have fun Brah.!
